Hi all. I have a old K&B 40 motor that I've had about 22 years. It has always performed great and still does. I haven't changed anything internal infact I've never had it apart. 15% nitro fuel and I've even added extra castor oil which someone suggested.
Anyways, it will run on the ground or in the air for about 1 1/2 minutes 1/2 to full throttle. Then it starts to sag on rpm's. Finally quiting 30 seconds later. At that point, if you wet your finger and touch it, it sizzles. I've always run a 10-6 prop. I tried a 9-6 and same thing. It has great compression and runs like a raped ape at first.
I tryed richening the carb until it starts to blubber from being too rich, but will still heats up. I do have a pressure line to the tank from the muffler.
There is no cowl or any thing around the motor, completly exposed.
Why?? I can't figure it out. Any idea's???? Thanks Terry
