I am having problems tuning my 7.5 pro. I have had 3.5s in the past and have not had any problems getting them set right, but this one is kicking our butts.
I have read, and printed off everything related that I could find off of this fourm as well as off of the mecoa website. I have set up everything as recommended for starters, and have not been able to get the boat to run wot. It will idle all day long and still run if you only give it slight throttle. The throttle response seems good, but when throttled up, it will die after about 10-20 feet wot. I am sure it is running lean wot. I have tried to turn out the remote needle, with out luck.
I think the carburator is the problem, it looks aftermarket, is silver, and has a K engraved inside a circle. I think the problem is with the location of the barrel valve.
Any help would be great.
Thanks, Ryan
