propeller wrong way
propeller wrong way
Postby Simy200 » Tue May 23, 2006 2:03 pm
Hi , im beginer in marine stuff but not in rc stuff, I got a K&B 3.5 outboard engine , and when i start it , the propeller run in other than it supposse to run , my boat goes backside lollll. I also try by start the engine with my starter running the opposite way and the same things append. Why???
Tahnks a lot for your help
Simon
Simy200
Postby MECOA » Thu May 25, 2006 8:47 pm
Looking down at the top of the engine the flywheel turns clockwise. The engine may run either direction at idle or low RPM but will not run at backwards moderate to high RPM. Be sure you have the correct rotation prop. Look at how it cuts the water when it is turning. Looking from the back of the boat the prop should turn Counter Clockwise.
