I have an old 3.5 marine engine........I need help
Postby chrisu617 » Sun May 21, 2006 6:52 pm
I bought a boat with a 3.5 inboard from an old co-worker. I got no manuals, only the information he could give me through experience of playing with the boat for a couple of years. I unfortunatley cooked the engine a couple of years ago when I lost control and beached the boat. It screamed for a couple of minutes before I could get to it to shut it down. I really need some information on idetifying it properly so I can get new parts. It has a custom exhaust flange with water lines running in and out. Other than that it's pretty much the same as what's on the website. I just need to now if there are any distiguishing features that would tell me what year it was manufactured so I can get the proper parts. I really would like to rebuild it. It's a real screamer!!!! It's positively evil with a tuned pipe. If anyone can help me it would be awesome
Thanks.
chrisu617
Postby MECOA » Sun May 21, 2006 8:05 pm
these are the only changes...
Changes were made to the crankshaft.
Early 12mm, later 13mm.
Very early 3.5's sleeves had a smaller O.D. Crankcase I.D. and sleeve OD must be checked.
Early size is .750 -- Late/current size .765
Early 8906 had a clamped in prop shaft assembly.
New style will not fit. You must replace the entire lower unit.
K/B Inboard (Early)
Postby david brooks » Sat Aug 05, 2006 12:00 pm
I have an older 3.5 inboard also and don't know the number.
It is a front intake with exhaust throttle.
The venturi is located at 90 degrees off vertical.
Its missing the exhaust throttle...I hope I can still buy one.
david brooks
Postby MECOA » Mon Aug 07, 2006 11:26 am
Please start a new post next time.
For exhaust throttles try parther products.
http://www.pratherproducts.com/
