Which way does the wrist pin go / k&b 7.5 inboard
Postby sandiray123 » Fri May 27, 2005 12:56 pm
:( need to install wrist pin in older 7.5 k&b inboard which end goes in first?
sandiray123
Postby MECOA » Fri May 27, 2005 2:01 pm
If it uses a snap ring to hold the wrist pin in the open end goes in first
If it uses a teflon pad the pad faces the out ant goes toward the boost port opposite the exhaust
Postby mindstorm » Thu Mar 30, 2006 3:38 am
MECOA wrote:If it uses a snap ring to hold the wrist pin in the open end goes in first
I just purchased a new wrist with teflon pad.
the older I removed had the ring. This new with teflon needs to be locked or is it free to move a little bit as I noticed?
Bye, Mind
mindstorm
Postby MECOA » Thu Mar 30, 2006 1:25 pm
Remove the teflon pad if you use a snap ring or leave the teflon and let it float as per instructions above. It can have up to .060" movement.
