Which way does the piston install into the cylinder? Do the transfer ports in the piston follow the cylinder ports verticly? Or does the piston install oposite and the transfer ports (in the piston) only match up with the cylinder liner ports on top of the piston travel? :?: [http://s1216.photobucket.com/albums/dd365/maverickml7/KB%2091/]
Any help would be greatly appreciated thanks very much in advance.
