I just found a antique dennymite engine and wood prop ( although the prop has been repaired and for display only) at an estate sale.
There are numbers stamped on the mounting plate that is (C143) or (0143).
There is no plug in it or gas tank, but everything else looks real good. Have just dismantled it and cleaning with WD40........will take photos and assemple. ( gaskets look good) and everything looks good inside.
Not sure if these are glow or plug as I have looked on the internet and have seen somethin mounted to the shaft with a wire......which this one does not have.
Can anyone help with info on identifying the model/year, or any specific guidance?
Thanks Mike
