I need a carb for a older 7.5 K&B outboard
Postby boats » Fri Nov 14, 2008 11:26 am
I just bought a prather 31 with an older K&B 7.5 outboard. The carb that is on the engine has K&B stamped into it. I assume this is the old version of the carb. It is missing quite a few parts and according to your site if I understand it correctly the barrel is no longer made. I also got a newer stlye carb with the boat it is missing the mixture disk assembly and o-rings
part #85-5802, it is also missing the neck oring part #27-6782. And if I read an earlier post right it will also need a remote needle part# 9255 for this engine to run? How do I go about getting these parts??
thank you
Jeremy
boats
Postby MECOA » Sat Nov 15, 2008 9:25 am
We have some overlapping numbers for the same item
you can order by part number here
https://shop.mecoa.com/shopsearch.asp
85-5802 is the same as 85-8702
and
27-6782 is the same a 27-8782
I am going to break out the carb parts from the engine parts in the cart, but until then please use the above info. Thanks.
