Webra Record info
Webra Record info
Postby BRIAN PEART » Fri Apr 19, 2013 6:02 pm
I have a Webra Record 1.5cc with a Blue head it has beam and radial mounts I have read on line that the blue head model should be radial mount only could this engine still be original
look forward for any info on this engine
BRIAN PEART
Postby gossie » Sat Apr 20, 2013 7:40 am
There was one of those on eBay USA a couple of weeks back with it's red head brother.
We decided that it was an early MK2 version using a blue head like the MK1 radial mount motor and the radial 2.5 plain bearing.
The pair of them went for about $90.00.
Is yours a good one? i.e. Good compression, starts and runs well.
Postby Gluehand » Sat Apr 20, 2013 1:03 pm
If we're speaking of the same engine, it also (correctly) had the MkII head, but anodised in the "Bully" blue, not the MkI blue.....
Gluehand
Re: Webra Record info
Postby gossie » Sun Jun 09, 2013 9:36 pm
There's a blue head one in this lot with the beam and radial mount, as well as in the front a red head beam and radial Webra.
