Needle adjust Magnum .25
Postby Storm_rider » Sun May 04, 2008 8:10 am
WHen adjusting the needle setting on my Magnum .25 Ive only got 2 maybe 3 clicks of the needle before it stalls.Its hard to get this puppy to run reliably.
What gives?
Storm_rider
Postby Frank Klenk » Mon May 05, 2008 3:45 pm
Not knowing your engines history makes it a tough call, but there are obvious things to check. I assume it's a r/c engine? Check the following, air leaks at carb base, verify the fuel inlet has no blockage, spray bar not blocked or maybe a piece of dirt floating around, O rings on needles in good condition, head gasket not leaking, fuel tank not sucking air. It sounds like a lot but these are really base engine checks. Hope this helps.
Frank :)
Postby Storm_rider » Mon May 05, 2008 7:18 pm
I took everything apart last night.
O rings were cracked.
thanks for the help Frank.
Storm_rider
Users browsing this forum: No registered users and 67 guests
