Stallion 35 RC Gnrl Info
Postby WORNBOOTS » Sat Jan 26, 2008 5:10 pm
I came accross this engine in a buy-out still mounted on a test board and covered with dust, but before I try to restore it to flying cond. I'd like to know the proper steps. and yes that is dried blood on the prop which is probably why it was stored away.
What type and era plane should this be suited for?
What is your opinion of this engine from experience?
Pic's can be seen on my putfile page in the Stallion Album
Thanks for any info, its appreciated
Dan Z
WORNBOOTS
Location: Princeton, Texas between sarasota bay and the Mojave Desert
Stallion .35 R/C
Postby max hansen » Sat Jan 26, 2008 7:37 pm
Dan , Your engine was made in 1973 so any .29 to .40 size plane would be good . Falcon 56 or others that size. I flew the U/C version of this & they held up better than the Mc Coy's . Need fuel with at least 25% oil with some or all castor oil . If it is stuck ,heat it with a heat gun or a lpg torch on the cylinder . No ball bearings to worry about . Not a bad old chug . Good find . CYL, MAX H. :lol:
Postby WORNBOOTS » Sat Jan 26, 2008 10:03 pm
Max thank's
Its seen very little use and I dont think its ever run anywhere but on that board, needle is free and prop/crank does move. However I have not rotated it through a complete rev., maybe the old cub I have will work for it.
Dan
WORNBOOTS
Postby Frank Klenk » Sun Jan 27, 2008 7:28 am
Dan
Glad to see you made it back ok! I just went through your pics and you've got some nice stuff there. The Stallion is a nice find. They do run well and like was said already, use castor to keep it happy. I find they are a bit heavy compared to modern engines but good runners.
Cheers
Frank 8)
Postby WORNBOOTS » Sun Jan 27, 2008 7:40 am
Frank Thank You verry much for you effort, I'll try not to forget again.
did you see the McCoy 19 (Silver Head ??) on the old S-Ray?? it appears to have never been fueled.
Thank's....................Dan
Edit.......... In between the head-fins is a light blue residue, almost appears that the paint has just deteriorated???
WORNBOOTS
