Questions about: Anderson Spitfire, Edco Sky Devil, Hassad Blue Streak, Cunningham .647, Holland Hornet .049, Atwood .049, Forster, DEW/Kustom, and Remco only. These brands are owned by RJL Industries. Post Questions for other brands in Engine Talk above.
by max hansen » Thu Dec 20, 2007 8:42 pm
I am needing a Forster 99 connecting rod . Any idea when you will have one available ? Thanks Max H.
by max hansen » Tue Jan 15, 2008 7:02 pm
Just to let you know that the rod & other parts came VERY fast .
When I first looked in the engine it looked like a piece was broken out of the rod side beam .When I put in the new rod I found out that it was a casting flaw as it had nice rounded edges . The new rod was not a "I" beam but fit perfectly . Guess the Forster boys were lacking in quality control some what . Doubt if it would have failed but it was not run much as the hole in the spray bar was off about 90 degrees & was blocked . Live & learn . Thanks , MAX H. :lol:
Return to RJL Vintage Engines Tech Questions
Users browsing this forum: No registered users and 25 guests
