HP 61 GC Slide Carb Operation
Postby tutelar-rc » Tue Oct 02, 2007 9:11 pm
I have an HP 61 GC with Slide Carb.
I get 12,800 rpm with an 11x8 prop, main needle open 6 turns, slide open just past 1/2 way, idle needle clears slide when slide open all the way.
When I open the main needle more, the engine does not become rich (4 cycling). When I close the needle below 5 1/2 turns, I lose rpm.
I have cleaned the carb to ensure that there is no blockage...
My questions:
1. Can my needle setting be considered normal?
2. Is the slide carb open 1/2 way considered to be full throttle?
Thanks for your assistance...
tutelar-rc
Postby tutelar-rc » Tue Oct 02, 2007 9:15 pm
Two other items that are probably relevant:
1. I am not running a pressurized tank
2. Engine idles very well at 2,800 rpm
tutelar-rc
Postby MECOA » Wed Oct 03, 2007 3:27 pm
You must run pressure to the tank and the slide should open all the way. You will have to research why it is not opening.
Postby tutelar-rc » Wed Oct 03, 2007 4:56 pm
The slide will open all the way.
When I open it all the way while running the motor, the motor immediately loses rpm and will stop if I do not put the slide down below 1/2 open - seems to be starving for fuel...
tutelar-rc
Postby MECOA » Thu Oct 04, 2007 8:42 am
The pressure should solve that.
Postby tutelar-rc » Tue Oct 09, 2007 9:41 pm
THANKS! Pressure solved the problem.
I have finished tuning the engine and have it back in my Schluter Heli-Boy - runs GREAT now! :D :D :D :D :D :D
Head temperature after 10 minute flight is 183 deg F. Is this the right operating temperature?
tutelar-rc
Postby tutelar-rc » Tue Oct 16, 2007 8:09 pm
Bump.
tutelar-rc
