CONTROL LINE FUEL
CONTROL LINE FUEL
Postby JOHN G » Thu Sep 27, 2007 5:36 am
I CAN GET ALCOHOL FROM HD OR LOWES
AND CASTER OIL FROM CYCLE SHOP WHERE DO YOU GET
NITROMETHANE
THANKS FOR ANY INFO
JOHN G
JOHN G
C/L fuel
Postby chiefss » Mon Oct 01, 2007 4:05 pm
Used to be able to get nitro from racing shops. It was usually cut with alcohol. It ain't cheap. It isn't worth the effort though. By the time you get everything it would have been cheaper and easier just to buy fuel ready to go. Also, you have no idea what the purity of the alcohol is nor the oil. If the oil isn't degummed, it will varnish up the engine. Bakers is the only maker of degummed castor that I know of.
Fuel
Postby Reptile » Fri Nov 02, 2007 11:33 pm
You can get Bakers AA Castor as well as Klotz oil from Sig manufacturing. Don't buy alcohol from anywhere but a racing shop that sells Racing Methanol and Nitro. They carry pure Nitro and Methanol that is 99.9% pure (no Water) You can probably find a speed shop locally by looking on the internet under "VP Racing Fuels" or "Nitrofuel". Most of them will carry Nitro and Methanol by the gallon.
Don
Reptile
FUEL
Postby JOHN G » Sat Nov 03, 2007 6:07 am
DON
I'LL GIVE IT A SHOT
THANKS JOHN G
JOHN G
Return to 1/2A and alike
