Will this P/L fit my 8907?
Postby anoolite76 » Thu May 24, 2007 8:27 pm
Hello,
Can you please view the photo of these two pistons/liner sets and tell me...
I have two piston/liners for my 8907, but only one seems to match the parts existing in my current engine. Is the liner in the picture with the square ports intended for my 8907 outboard, or is this liner for a different K&B engine? I bought the p/l from another model boater, told it was for a .21 K&B outboard.
Here is the picture:
http://relentlessskateshop.com/KB_piston_liners_21.jpg
Thank you in advance,
J.T.
anoolite76
Postby MECOA » Thu May 24, 2007 9:35 pm
Through the years both styles were used in all engines. We use the one with the square taller ports in the SS and SX and the one with the raised center in the 8907. Both will work in either engine but the one with the square posts is pipe timing and will produce higher RPM with the right exhaust system.
Postby anoolite76 » Thu May 24, 2007 9:42 pm
Thank you kindly for your reply!
anoolite76
Postby anoolite76 » Fri May 25, 2007 6:16 am
It seems that my wrist pin with the teflon pad does not slip into the piston matched with the square ports. Is this remedied by simply de-burring the recess for the wrist pin until it fits, or is this piston designed for a different wrist pin?
Thank you again in advance,
Jeffrey
anoolite76
Postby MECOA » Sun Jun 03, 2007 10:47 pm
It should fit, the pin never changed.
Users browsing this forum: No registered users and 235 guests
