K&B 7.5 outboard
K&B 7.5 outboard
Postby KernalFlagg » Tue Jan 09, 2007 9:45 pm
I have an older K&B 7.5 outboard, I believe it is an 8701, possibly an 8702. It has a square carb.
My question: Can I buy a later model carb, such as the Kavan carb to replace the one I have that is really worn out. Or is it possible to buy a new square carb? The needle valve assembly on mine is pretty much shot as is the barrel stop screw.
Is also need to buy a new prop.
Any help, especially on the carb, would be GREATLY appreciated!
KernalFlagg
Postby MECOA » Wed Jan 10, 2007 10:21 am
We have all the parts for the square carb but not complete carburetors
see
http://www.mecoa.com/kb/carbs/carb4061.pdf
Depending on the neck diameter you can use the Kavan carb
Unfortunatly the later 7.5 uses a .625 diameter and kavan has none that big.
we carry Prather props listed here
http://www.mecoa.com/acc/marine/index.htm
Users browsing this forum: No registered users and 172 guests
