by romano » Thu Mar 02, 2006 5:47 am
I have purchased a spitzy 049. Good compression, runs on a prime, will draw fuel up to carb. Neddle valve clear all directions. Fuel is Novel 25%, plug ok. Won't keep running.
Any ideas pease.
Thank you,
John L
romano
by Jim Thomerson » Fri Mar 03, 2006 2:37 pm
Maybe the backplate is leaking. Do you have the Spitzy 045 with the intergral tank underneath or the Spitfire 049? Never had a Spitzy, but had a backplate leaker Spitfire.
by max hansen » Sat Mar 04, 2006 9:53 am
Many years ago I had a new OK .074 Cub that would just run out the prime . I found out that the spray bar was not installed correctly . If you can see a hole in the spray bar by looking in the intake ,something is not right in Denmark. Good luck MAX H. :lol:
Return to 1/2A and alike
