KRAFT .61 LINER REMOVAL
Ask questions about the RJL K.61, Kraft .61 and RJL/Cox/K&B Conguest .15 here
Postby JBKIWI » Tue Feb 21, 2006 3:34 am
RE KRAFT .61 LINER REMOVAL.
(FOUND INFO ELSEWHERE ON THIS SITE.) INTO THE OVEN AT 180 DEG. CELSIUS FOR 10 TO 15 MINS,(AFTER REMOVING ALL BITS WHICH MIGHT MELT) A BIT OF TWISTING AND OUT IT CAME. WILL REPLACE THE BEARINGS AS THE HEAT MAY AFFECT THE SEAL ON THE FRONT BEARING. BEARINGS ARE OLD AND NEED REPLACING ANYHOW.
CHEERS
JBKIWI
Postby MECOA » Wed Feb 22, 2006 9:58 pm
http://www.mecoa.com/faq/cyl/remove.htm
Bearing seals are good up to more than 280 f
Return to RJL Engines Tech Support
