K & B .40 # 4011 / J93 4011
Postby jerry07_58 » Thu Jul 07, 2005 6:35 pm
Hello All,
I have a chance to purchase a NIB K & B .40. The only thing missing is the Needle Valve and Muffler screws. I have searched the parts manual to see what I need to order but I am a little confused.
On the mounting ear of the engine it indicates "J93 4011". I assume this indicates the manufactured year "1993".
Can someone direct me to the correct carburetor parts break down? I am assuming it is this one.
Ref. http://www.mecoa.com/kb/carbs/carbsptstr.pdf
Your help would be highly appreciated.
Thank You
jerry07_58
Postby Atomic » Thu Sep 15, 2005 10:02 pm
any .45 sportster carb should be a direct bolt in replacement on this engine.. you might have more luck trying to find one of those whole. also, any of the old 2 needle k&b carbs should work as well.. as long as the throat diameter is the same.
-Joe
Atomic
Postby Jim Thomerson » Sat Sep 17, 2005 7:46 pm
Muffler screws on the K&B 4011 are 5 x 40. I have one where the previous owner made 6 x 32's work.
Jim
Postby Karl stier » Sun Jul 29, 2007 8:30 pm
i need so info. i am putting a O S 30vg on my t max truck.i had a oroin 21 in it.if you could give a few ideas. looks like i will have to move the transmission foward slightly :roll:
Karl stier
