16-8901 rod- will it fit the older 3.5's?
Postby summerwind » Wed Nov 02, 2011 10:22 pm
having an older 3.5, and not sure which rod will fit.
the only listing i see so far is the 16-8901
summerwind
Postby MECOA » Sun Nov 13, 2011 10:06 am
this fits all 3.5's, just be sure the edge of the rod clears the case on really old 3.5's You may have to dremal inside the case slightly where the cylinder bore in the case meets the crankshaft bore in the case.
https://shop.mecoa.com/shopexd.asp?id=333
