.91 or .67???
.91 or .67???
Postby Jack Fusion » Tue Mar 01, 2011 10:26 am
I have 4 engines that I need to confirm the size of them. The number on the cast mounting bar is H92082 ( 3 of them ) and the other has 0003145.
I have been told that the 0003145 is a .67
Can anyone tell me what size these are?
Are the blocks the same for both these engines and just the crankshaft and piston/sleeves different?
Jack Fusion
Postby Frank Klenk » Tue Mar 01, 2011 4:23 pm
Jack
We're going to need more info before we can help. What make are they? Are you able to post pictures? Please advise.
Frank
Postby Jack Fusion » Tue Mar 01, 2011 4:33 pm
They are K&B inboard engines. They look identical as the .67 family on the K&B website. I am hoping someone can identify them from the # on the casting. I don't have any pics right now but will work on that.[/url]
Jack Fusion
Postby Frank Klenk » Tue Mar 01, 2011 4:38 pm
Jack
Click here for directions to post a picture. Or, if you wish email the pics to me and I can post them for you.
http://www.modelengine.org/forum/viewtopic.php?t=6022
Best
Frank
Postby SteveM » Tue Mar 01, 2011 4:50 pm
If the outside dimensions are identical between the four motors, why not pop off the cylinder heads and measure the piston diameter and piston stroke and do the math.
Postby Jack Fusion » Tue Mar 01, 2011 8:19 pm
The 3 engines don't have pistons or sleeves in them. I wanted to order the sleeve and piston but didn't know if I could just choose the .91 or if the blocks were different. The one that is supposed to be a .67 is complete and if I can find out from the block #'s then I will have to disassemble and measure.
Jack Fusion
Postby Frank Klenk » Sat Mar 12, 2011 8:26 am
Here are some pictures ...
Users browsing this forum: No registered users and 39 guests
