what fuel
what fuel
Postby capsnt » Sun Jan 16, 2011 1:21 pm
What fuel and % works best in .46 marine
capsnt
Postby chiefss » Sun Jan 16, 2011 6:05 pm
Depends on what engine and what you plan on doing with it. Sport 40? , Three point hydro? K&B? OS?, OPS?
Postby capsnt » Mon Jan 17, 2011 9:14 am
chiefss wrote:Depends on what engine and what you plan on doing with it. Sport 40? , Three point hydro? K&B? OS?, OPS?
Dumas U1 Hydro
capsnt
Postby capsnt » Mon Jan 17, 2011 9:41 am
I going to use it on a Dumas atlas van lines 36" hydro
capsnt
Postby SteveM » Mon Jan 17, 2011 2:29 pm
The type of motor is more important to know that the hull. Will you be using an ABC high performance marine motor, ringed sport motor, converted airplane motor or perhaps a four-stroke marine?
For an ABC high performance 7.5cc marine motor like an OS , OPS, Picco or K&B then 40% nitro fuel is fine.
Postby capsnt » Mon Jan 17, 2011 2:43 pm
Mecoa .45 marine
capsnt
Postby SteveM » Mon Jan 17, 2011 5:17 pm
capsnt wrote:Mecoa .45 marine
The specs indicate that this is a hard chrome ABC motor with dual ball bearings, so that's good. The online picture shows a side exhaust motor in the tradtional airplane style, so it isn't a front or rear exhaust high performance type. I'd suggest 25% to 40% nitro fuels.
Postby capsnt » Mon Jan 17, 2011 5:40 pm
capsnt
