Rusty bb
Rusty bb
Postby dieselfun » Tue Sep 28, 2010 7:40 am
Is any way to get rid of rust in ball bearings, without dissambling an en gine?
Regards,
dieselfun
Postby SteveM » Tue Sep 28, 2010 8:05 am
Once your bearings have any rust they need to be replaced.
Postby dedaddy007 » Tue Sep 28, 2010 8:08 am
Once ball bearings are rusty, you should replace them.
The best way I have found to remove rust from ball bearings or any steel parts is to soak them in EvapoRust from www.theruststore.com. It removed rust without touching the base steel.
But you should replace the rusty ball bearings for best results.
dedaddy007
Rusty
Postby dieselfun » Tue Sep 28, 2010 8:10 am
[quote="SteveM"]Once your bearings have any rust they need to be replaced.[/quote]
Thnks for your advise.
Regards
dieselfun
Rusty
[quote="dedaddy007"]Once ball bearings are rusty, you should replace them.
But you should replace the rusty ball bearings for best results.[/quote]
Thnaks for your advise.
Regards
dieselfun
Users browsing this forum: No registered users and 125 guests
