Spark plug repair?
Spark plug repair?
Postby tag » Sat Apr 01, 2006 3:55 pm
Has anyone tried to repair a spark plug when the center electrode (wire) has come loose? What did you use and what was your procedure? I have several like this and with the price of new ones, they get expensive.
Tom
tag
Postby aaronnovak1999 » Tue Oct 17, 2006 7:29 am
Tom,
On older friend of mine said he would "repot" the center electrode using plaster of paris. Almost using it as an adhesive. Ive also heard of very pure CYA type glues being used as they handle high temperature well and have the same COE as the Insulator. Hope this gives you some ideas.
aaronnovak1999
Postby walt » Wed Jan 31, 2007 8:53 pm
I used to seal and repair the cracked and broken porcelain portions with JB Weld. Never had a problem.
walt
Postby cessnajfb » Mon Mar 22, 2010 6:58 am
walt wrote:I used to seal and repair the cracked and broken porcelain portions with JB Weld. Never had a problem.
I have v2 plugs with Champion insulators.
Frank
cessnajfb
Postby Frank Klenk » Tue Mar 23, 2010 2:54 pm
Hi Tom
I have had good success by using thin CA and wicking it into the plug from the top side. So far, no issues at all.
Frank 8)
New Plugs with Champion Insulators
Postby cessnajfb » Tue Mar 23, 2010 3:07 pm
cessnajfb
Users browsing this forum: No registered users and 22 guests
