Outboard Lower Unit Screws and Prop Shaft Assembly Trouble
Postby 3aw » Tue Sep 08, 2009 8:46 am
Loosing lower unit screws and prop shaft nut and assembly keeps backing off...
Any recommended fixes?
I thought of using lock-tite on all treads.. but not sure if this should be used on the propshaft assembly.
Thanks!!
Aaron W.
3aw
Postby MECOA » Sun Sep 13, 2009 6:22 pm
This is most likely the caused from an unbalanced prop. Check that first.
