Removing FlyWheel on 7,5 inboard
Postby HardShooters » Mon Aug 24, 2009 8:22 am
New to Nitro boating so bear with me..
Doing an Inspection of my K&B 7.5 (9181) i have noticed some of the bolts on the engine have worked there way loose..
My question is this How does the flywheel come off?? as i have to remove it to get to the bolts behind it on the motor casing..
Is it pressed on or threaded??
Motor is a K&B 7.4 inboard (9181) steel flywheel
also should i put some (blue) lock tight on all screws and bolts ??
thank you for any help..
HardShooters
Postby HardShooters » Mon Aug 24, 2009 8:26 am
sorry typo not 7.4 is a 7.5
HardShooters
Postby SteveM » Mon Aug 24, 2009 9:42 am
The flywheel has a hole drilled on the side into which you slip in a rod( drill bit works) of the proper size. You then loosen the hex coupler and the flywheel should pop off. It it seems stuck, then thread on an acorn not of the proper size and while holding the flywheel in one hand give the acorn nut a gentle tap with a hammer.
Postby HardShooters » Mon Aug 24, 2009 10:29 am
Thank you very much for the fast Response
HardShooters
Postby HardShooters » Mon Aug 24, 2009 4:04 pm
worked like a dream.. again thanks...
HardShooters
Postby SteveM » Mon Aug 24, 2009 5:00 pm
Glad to have helped.
Users browsing this forum: Google [Bot] and 95 guests
