Converting RC engine to C/L engine
Postby racauth » Mon Aug 10, 2009 9:09 am
Saw a Super-Tiger .074 at a local model shop. It is rigged for RC with
2 adjuster screws (idle & high rpm) and throttle lever(for the servo) .
Since Control Line is basically full throttle flight only, why could i
not make and attach an an "adjuster rod" connected to the
engine's throttle lever ? The salesman seemed discouraging to the idea.
1. I would have to attach glow wire.
2. I would start it on low RPM, and adjust throttle lever upward to nearly full throttle for C/L flight and fly it until fuel exhausted.
Is there anything i am missing here other than crafting and attaching
a throttle lever?? or Is there something peculiar to RC throttle engines
and their operation??
thanks
racauth
Postby chiefss » Mon Aug 10, 2009 1:35 pm
I don't think Super Tigre ever made a .074. Maybe a .74 but nothing that small.
Of course you can wire the throttle wide open and use it on a C/L airplane. I do it all the time. Won't be as powerful as a straight venturi as the choke diameter is usually smaller on R/C carbs for better Idle characteristics. I don't know why your Hobby Shop said not to he doesn't obviously doesn't know much about model engines.
The biggest difference between C/L engines and R/C engines by the same manufacturer is the carb vs the straight venturi.
There is no reason you can't start the engine at full throttle. How do you think you start a C/L engine? Just be careful when starting it.
Postby racauth » Sat Aug 15, 2009 11:38 am
My mistake,
Thunder Tiger, GP-07 engine.
Displacement 0.069 cu.in.
http://www.tiger.com.tw/product/9007.html :oops:
racauth
Postby chiefss » Sat Aug 15, 2009 2:02 pm
What happened to the other posts that were on this thread?
Postby racauth » Sat Aug 15, 2009 2:43 pm
I originated the thread last Monday, and i dont think there were any other posts other than yours and mine.
racauth
Postby 10%_nitro » Sat Aug 15, 2009 5:47 pm
10%_nitro
Postby chiefss » Sat Aug 15, 2009 10:18 pm
You're right. It was a different thread but yes you can use an R/C engine on a C/L airplane with no problem.
Users browsing this forum: No registered users and 90 guests
