chiefss wrote:Carefully
By the way, it's a BABE BEE, not a Baby Bee.
chiefss wrote:You could and I have. I still have a Roberts three line control handle and the bellcrank linkage for same. Haven't used them in years.
However, he didn't ask about using a throttled engine. He asked if he could lock the throttle wide open and run it as a C/L engine and the answer is yes.
chiefss wrote:You stated that the crankshaft and sleeve timing were different in the FSR-S engines and they aren't. They all use the same parts. At least that's what the OS parts manuals says and I tend to believe that. That and I have both types of engines and and the only differences are the venturi or carburator. The choke area of the 4B and 4BK carbs is less than the straight venturi but that just affects the total output. If you interchange them both engines run the same as when the carb/venturi combination was reversed. I've tried that.
I run both my 40 and 45's on either a 10x6 or 11x6 and have never had an overheating problem.
chiefss wrote:...A Flite Streak isn't the greatest C/L trainer made.
spacebug.049 wrote:I also happen to be getting into control line. I am building a PT-17 for a Cox Baby Bee. There is no one in our town that I know of that currently flies control line. I know where I could fly it but no one to teach me. Any suggestions on how to start off?
Hunter
Users browsing this forum: Google [Bot] and 17 guests
