Super Tigre G .40 RR
Postby max hansen » Fri Dec 19, 2008 5:34 pm
Would like to know the location of the intake port on this engine .It is now at the upper right position ( 1 o'clock ). I found a G .61 on eBay that has it at the lower left (7 o'clock). What is right ?Also is it a ABC or just lapped piston ? Thanks, Max H. :?
Postby ron bennett » Sat Dec 20, 2008 10:58 am
Hi Max,
Either 1 o'clock or 7 oclock is correct for aero rotation. 4 o'clock or 10 o'clock is for reverse rotation. This engine can be either lapped iron in steel or ABC, depending on the vintage.
Ron Bennett
ron bennett
st .40
Postby max hansen » Sat Dec 20, 2008 11:26 am
Thanks Ron ,I just wanted to make sure it was together right . Max H. :D
Users browsing this forum: No registered users and 118 guests
