forster 29
Questions about: Anderson Spitfire, Edco Sky Devil, Hassad Blue Streak, Cunningham .647, Holland Hornet .049, Atwood .049, Forster, DEW/Kustom, and Remco only. These brands are owned by RJL Industries. Post Questions for other brands in Engine Talk above.
forster 29
Postby jaregalbuto » Mon Apr 11, 2016 6:27 am
Can RJL supply correct cylinder head and crankcase screws plus head gasket for 50's
Forster 29 front rotary valve? If so need ordering data. Thanks
jaregalbuto
Re: forster 29
Postby MECOA » Wed Apr 13, 2016 8:16 am
https://mecoa.biz/shopdisplayproducts.asp?id=106
The head gasket is the only thing that varies. Later .29 have a step in the top of the cylinder so the .35 head fits both. Hence the gasket is the same for the .29 and .35
Early version .29 has a head gasket with a smaller ID
Return to RJL Vintage Engines Tech Questions
