Testors McCoy .35
Questions about: Anderson Spitfire, Edco Sky Devil, Hassad Blue Streak, Cunningham .647, Holland Hornet .049, Atwood .049, Forster, DEW/Kustom, and Remco only. These brands are owned by RJL Industries. Post Questions for other brands in Engine Talk above.
Testors McCoy .35
Postby Twanger » Thu Mar 23, 2006 3:18 pm
I recently read that it isn't good to use an electric starter on the Series 21 Testors McCoy .35, as there is no thrust washer behind the prop drive plate. Is there a way to remedy this? Could a person use a thin steel washer if one could be found to fit? --Twanger :( :?:
Twanger
Postby MECOA » Sun Mar 26, 2006 2:53 pm
Yes a steel washer about .010" will work.
Return to RJL Vintage Engines Tech Questions
Users browsing this forum: No registered users and 24 guests
