Problem with HB.20
Problem with HB.20
Postby packard » Mon Feb 19, 2007 1:25 am
Hello, I just found this wonderful forum.
I bought a HB .20, new in box. It started very well and I flew some tanks to my satisfaction. I use the engine in controlline. So , during my last flight, the engine strted to run lean and there was no way that I could intervene.
After this one lean run, the engine had lost its compression to the extend that it will not start anymore. Question: is this normal engine behaviour? Or is there a trick that I am missing? Through this forum I now know that this version engine does not have a top L-ring. If wear made the cylinder/piston fit sloppy, are there still new sets around for me to buy?
Gerben Wassenaar,
Netherlands
packard
Postby MECOA » Mon Feb 19, 2007 10:34 pm
The cause of the lean run was probably debris in the carb.
http://www.mecoa.com/faq/carb/debris/carbdebris.htm
The HB .20 has a lapped iron piston and steel liner while the .21 and .25 have dykes rings
the part number is 33-1101
https://shop.mecoa.com/shopdisplayproducts.asp?id=111
Users browsing this forum: Majestic-12 [Bot] and 11 guests
