another id problem
another id problem
Postby layback2 » Sat Dec 10, 2005 9:29 am
i have a engine not saying it is a HB or not sence i can not find any id marks on it except made in germany it is quite large maybe a 61 or larger and on the bottom of one of the engine mounts the number is stamped 11.85 and the black carb thats on it is (not) square it has a bevel in the center of the front and if you measure the lenght from the front end of the crank to the back plate it is 4-3/8 in lenght and the measurement for the height is 3-7/8 for the motor i had to come to A FRIENDS TO CHECK THIS SITE OUT FOR INFO because your new server has a problem on my isp but you can email me any information that you may find at russlandreth@hotmail.com thank you
layback2
Postby MECOA » Sat Dec 10, 2005 8:55 pm
Does the engine have anything on the bypass? Like a milled off area? Some HB were sold with a HEGI logo and later this logo was removed by HB as thay had many extra castings.
another id problem
Postby layback2 » Sun Dec 11, 2005 8:48 am
no not that i can see no logo of any kind is there a way to send you a photo of the motor so you can see it for your self
layback2
another id problem
Postby layback2 » Mon Dec 12, 2005 11:05 pm
I sent the pictures to you thanks now maybe we can figger this engine out
layback2
Postby MECOA » Sat Feb 11, 2006 8:43 pm
Just so everyone knows it was an HB .61 with the name neatly filed off.
HB (German) engines Tech Questions
Postby layback2 » Sun Feb 12, 2006 6:38 am
Between me and the world this is the best engine i have ever run and i have tryed quite a few different ones i have no problems with it starting or stay runing no matter what the plane is doing inverted or not thanks
layback2
Re: HB (German) engines Tech Questions
Postby Aquaman » Tue Jan 29, 2008 6:59 pm
layback2 wrote:Between me and the world this is the best engine i have ever run and i have tryed quite a few different ones i have no problems with it starting or stay runing no matter what the plane is doing inverted or not thanks
You and me both, HB engines are the best that I've ever used.
Aquaman
Users browsing this forum: No registered users and 30 guests
