HB 40 crankcase gasket size
Postby bamawig » Sun Feb 06, 2005 6:23 am
I purchased a couple of gasket sets ( part no. 291001) for a HB 40. The set contains two gaskets that fit the rear cover. The front cover ( crank itself) is larger than the rear and the gaskets won't fit. I don't see any other gaskets listed for the crankcase. What gives? Thanks in advance for your help.
bamawig
Postby MECOA » Mon Feb 07, 2005 6:31 pm
Yes it will fit. Soak it in some WD40 and it should slide over the bearing. These are the only ones we ever had for the HB40
Postby Redwulf__34 » Thu Jun 19, 2008 5:21 am
I have a late .40 PDP and need the rear gasket. I know you have them but I was hoping to get the old engine running for this weekend. I made a gasket from some high temp non asbestos material that is exactly 1/32" thick. Because the old gasket was a melted mess when I pulled the case I don't know how thick the orginal was. Is the gasket material too thick? Will it cause a problem until i can receive some new gaskets from you?
Sean
Redwulf__34
Postby MECOA » Mon Jun 23, 2008 12:22 pm
