VT 49 Valve Shim
VT 49 Valve Shim
Postby Imhoff43 » Sat Mar 21, 2009 4:44 pm
Were can I find the procedure fro shimming the valve?
Imhoff43
Postby MECOA » Tue Mar 31, 2009 7:57 am
The valve needs .003 - .005 of an inch clearence. You have to assemble the head until the valve drags and remove the appropriate shims.
No an o-ring will not work for sealing the valve. It works on an oil film. Ude the right fuel and it works great.
Users browsing this forum: Bing [Bot] and 1 guest
