HP 49 VT Exhaust header question
Postby Dad_Roman » Wed Dec 05, 2007 1:13 pm
Hi, I have an Austrian version that I've recently acquired. The header swivels up and down as the engine revs. Is there a gasket or copper ring that should insert in the head before installing the header nut? The header is not flared at the end of the pipe for the nut to grab onto and seal, should there be some sort of flange or flare on the end of the header pipe? Is there an exploded diagram to properly identify the parts of this engine? Thanks for the help...Shane
Dad_Roman
Postby MECOA » Wed Dec 19, 2007 9:30 pm
Yes there is a thick copper gasket thet goes in first. Part number 29-2431
https://shop.mecoa.com/shopdisplayproducts.asp?id=124
Postby Dad_Roman » Wed Dec 19, 2007 9:33 pm
Gotcha! Thank you sir. And Merry Christmas to you and yours.
Dad_Roman
Users browsing this forum: No registered users and 41 guests
