HP 61 - mixture adjustment
Postby Lysander » Mon Nov 13, 2006 10:57 am
I have been given an HP 61 which must be over 20 years old but runs beautifully still. This is a make of glow motor that I have not seen before and I wondered if there is an adjustment for a second needle? I don't suppose there is a pdf file manual I can download for the engine? It is all silver with a front mounted carb. It has a knurled needle vlave adjustment for the main jet and below that is a much large knurled disc about 1/2 in diamater - if that helps identify the particular variant. If it is possible to post jaypegs I could send a picture but as a new member don't know if this is possible.[/img]
Lysander
Postby MECOA » Tue Nov 14, 2006 9:15 pm
The large disk is the idle mixture adjustment. It should only be moved 5 degrees in either direction.
Postby Lysander » Wed Nov 15, 2006 1:25 am
Many thanks for that information.
Lysander
Users browsing this forum: No registered users and 79 guests
