dbarn wrote:I wonder if anyone can help me? My HP61 is a 4 bolt head, front induction, with the cylinder barrel separate from the main crankcase, held to it by those four long bolts. Should the seating between the barrel and the main case have a gasket? Should a gasket also be between the barrel and the top of the liner? I have the main head gaskets, which seal the liner/cylinder head only.
Users browsing this forum: Majestic-12 [Bot] and 33 guests
