VT 21 running Problems
Postby davideo4301 » Fri May 12, 2006 7:28 am
VT 21 running Problems with my little VT 21 will only run for a few seconds and will not pick up speed. I have tried setting up the timing according to the posted information but it is a tricky operation, to view ports through intake and exhaust openings. Is there another way to set the timing for this sweet little engine? Any Suggestions? David
davideo4301
Postby MECOA » Fri May 12, 2006 8:24 am
Sorry that is the only way to time it.
Did you look at....
http://www.mecoa.com/faq/vt/timing.htm
Users browsing this forum: No registered users and 15 guests
