HP VT 49
HP VT 49
Postby Jeza » Fri Jan 27, 2006 12:18 am
Hey there
I was given what looks to me like a VT 49. It says made in Austria on the side. I would like to know what sump oil to use or if it does use sump oil? There seems to be a little drain plug at the bottom.
Unfortunately the engine did not come with a muffler. I live in Johannesburg, South Africa, do you know of any dealer that would stock this part or is there possibly a generic part that would fit?
Jeza
Jeza
Postby MECOA » Sun Jan 29, 2006 8:26 pm
No sump oil...
here's the owners guide
http://www.mecoa.com/hp/vt/guide.htm
I don't know of anyone stocking parts. You can order direct from us.
Postby Jeza » Tue Jan 31, 2006 12:51 am
So then why is there a drain plug at the bottow of the motor?
Jeza
Postby MECOA » Wed Feb 01, 2006 10:14 am
As it states in the owners manual this cap/drain plug is for flushing the lower end.
quote from owners guide...
AFTER FIRST RUN it is a good idea to flush out the lower crankcase thru the lower vent nipple and cap. Clean fuel should be used for this and engine must be run again to remove excess alcohol. Then after run oil should be added thru lower vent tube.
I will change the term "cap" to "drain plug"
Postby Jeza » Thu Feb 02, 2006 12:57 am
ok cool thanks so much for your help!! This is basically a 2stroke motor with 4 stroke valves as it doen;t have sump oil - crazy!!! So this motor will actually smoke like a 2 stroke?! how old do you think my motor is if it says 'made in austria'
Jeza
Postby MECOA » Sat Feb 04, 2006 8:07 pm
pre 1990
Users browsing this forum: No registered users and 2 guests
