HP .61 Gold Cup
HP .61 Gold Cup
Postby ctoms » Sat Oct 01, 2005 11:16 pm
I have a new in the box .61 GC with the rotary carb with the large disc idle screw.
I am looking for a starting point for the needle valves because the small(high speed?) needle was removed by prev owner.
I also would like someone to explain the big disc(idle?). Does it only rotate in place and not go in and out? There is a notch cut into it, what is that for? I turned it in and out several times with no movement in and out that I could see. This would mean the manual is hard to understand because the starting point is 2 1/2 turns out for the idle valve. This is why I am asking the question.
I am also wondering about the small needle valve or the high. The manual says 4 turns out but that would cause one of the O-rings to be exposed.
I seem to think I have the wrong manual for this carb and need to understand this carb.
Charlie
ctoms
Postby MECOA » Wed Oct 12, 2005 8:00 am
The large disk is a mixture disk. The notch should be pointed directly at the intake. This only requires about 5 degrees of movement to adjust. The adjustment is very simular to this.
The amount of turns out for the high speed needle is just a starting point. This will be a rich setting.
read this
http://www.mecoa.com/faq/carb/needle_aero.htm
Users browsing this forum: Bing [Bot] and 1 guest
