.67 Marine Inboard, flywheel
Postby Charlottedarter » Wed May 21, 2008 8:01 pm
I have installed the new crankshaft I received from you in my .67 K&B, marine inboard, and am having difficulty getting the flywheel to seat on the crank shaft extention out the end of the motor. Is there a trick to getting it to seat? I realize it is a compression fit, but I would rather get it right rather than break something.
Help please!?
Charlottedarter
Postby MECOA » Wed May 28, 2008 10:14 am
You must tighten the flywheel nut to make the collet colapse and seat on the shaft.
Users browsing this forum: No registered users and 30 guests
