PLEASE HELP,WHAT ENGINE IS THIS?
Postby fallover » Sun Mar 11, 2007 8:57 am
I HAVE AN OLDER K&B ENGINE, FOR INSTANCE A .61 HAS THE HEAD MEASURING 44.1 MM WIDE, 14 FIN , EXHAUST IS 38.4MM CENTER TO CENTER TO HOLES OK, MINE IS HEAD SIZE 50.2, 16 FIN, EXHAUST IS 39.0 MM CENTER TO CENTER, HAS 3 FIN ON SIDE OF CASE, RADIAL BACK MOUNT, CARB THROAT OPENING IS 15.4 INSIDE DIA., PLEASE HELP RECENTLY BOUGHT THIS AND IT WAS ADVERTISED AS A .61 ENGINE, ALSO NEEDS CARB NEEDLE VALVE ASS. TO GET RUNNING THANKS FOR YOUR HELP :?
fallover
Postby fallover » Mon Mar 12, 2007 2:49 am
forgot to add ,the head is a 4 bolt pattern
fallover
Postby MECOA » Fri Mar 16, 2007 7:11 pm
As written in our parts dept
http://www.mecoa.com/kb/parts.htm
Sportster engine family consists of 3 sub families. The .20 & .28, the .45, and the .65
Complete History for .20 & .28 .45 .65
Distinguishing features: 4 bolt head, Made in USA on one side of case, K&B (not oval logo) on other side. Some had size stamped on mounting lug but most had no size reference. Plain bearing engine. You can determine the size by counting the cylinder fins... the .20 & .28 have 9 fins, the .45 has 10 fins, and the .65 has 13 - Click on "Model No." to see picture.
you have a Sportster 65
Postby fallover » Sat Mar 17, 2007 10:20 am
it threw me off because the head size was so much bigger than my other sportster, thanks for your time
fallover
Users browsing this forum: No registered users and 46 guests
