.82 PN-5350 accessories
Postby MIU » Mon Jan 09, 2006 2:44 pm
I am going to run this motor in a Deep Vee boat. I want to know what clutch will work on it.
And what tuned pipe should I use?
I did not buy this motor yet, but it is the one I like best. It must have a clutch. Any suggestions?
MIU
Postby MIU » Tue Jan 10, 2006 6:41 am
No tips for this?
MIU
Postby MECOA » Wed Jan 11, 2006 8:51 pm
You posted this in 3 spots on this site.
No clutches are available. None, nada.
If you were to use a clutch you would have to run a water pump too because cooling water is picked up off the moving prop.
Mac and Prather make tuneded pipes.
Users browsing this forum: No registered users and 33 guests
