by Jim Johnson » Thu Aug 14, 2014 2:16 pm
What I would like to know is about the GMS 61 ring piston and liner .. I have what I believe to be a new GMS 61 ABC ring piston and liner .. it is not a dykes ring though. The liner appears to have the same dimensions as the K&B 61... the problem is the head on the K&B is for a baffle piston and the liner I have needs the head that goes with it.. so the question is this.. does the head on the GMS 61 fit on the K&B 61 ... Does K&B sell a head for an ABC engine?? I see the 61 ABC stunt engines once in a blue moon... are they ringed? It is hard to find detailed info on these engines..
Thanks Jim
Jim Johnson
by MECOA » Mon Aug 25, 2014 7:13 am
Engines are completely different.
go here and search by 11-61 for the K&B heads.
www.
https://mecoa.biz/shopsearch.aspBut I can not help you when you want to mix parts from one engine to another.
Users browsing this forum: Majestic-12 [Bot] and 74 guests
