by James C Harrell » Mon Feb 20, 2012 12:16 am
I have a K&B 6.5 marine I was attempting to break in. The pinch was real tight so I was taking it slow when I felt a bad feeling. It felt like a bearing so I pulled it down and did find a bearing that had a slight bad spot. It wasn't near as bad as it seemed like but still bad enough. Problem I have is that the bearings listed for the 7.5 family are not the right dimesions. The serial number on my engine is 0002393 and it is a 6.5. Both the front and rear bearings are the same size. Best I can figure is 22.11mm OD and 9.75 ID and 5.76 thick. Is there any way to make sure befor I buy this size or can I get them from Mecoa?
James C Harrell
by James C Harrell » Mon Feb 20, 2012 12:27 am
Made a mistake on the measurements. They should read as: OD 22.2mm, ID 9.5mm, and 5.5mm thick. Also both of these are non-sealed.Is that right?
James C Harrell
by MECOA » Tue Mar 06, 2012 7:24 pm
It would be our part numbers
18-0015
18-8778
inch size
BEARING .875 x .375 x .218
you can find them here
http://shop.mecoa.com/shopsearch.asp
Users browsing this forum: No registered users and 231 guests
