older 3.5 Aero conrod orientation
Postby summerwind » Tue Nov 01, 2011 10:28 am
have a new but older version 3.5............the rods in these engines had "K&B" embossed on one side of the rod......which way is it suppose to face?
front or back............
summerwind
Postby summerwind » Tue Nov 01, 2011 10:47 am
ALSO, THE WRIST PIN ENTERS THE PISTON FROM ONE SIDE ONLY.......WHICH WAY DOES THE PISTON GO?
WITH THE HOLE TOWARDS THE INTAKE PORTS, OR THE EXHAUST.
summerwind
Postby MECOA » Wed Nov 02, 2011 3:56 pm
The rod may have a champher on one side of the lower end
read this
http://www.mecoa.com/faq/conrod/whichway/whichway.htm
As for the WRIST PIN with pad
Usually the wrist pin with a pad will have the pad opposite the exhaust. The pad must always run against a portion of the cylinder. I can not pass over an open port. If it does it has the possibility of popping into the open port and causing damage.
you can see it here
http://www.mecoa.com/faq/whichway/piston/piston.htm
Users browsing this forum: No registered users and 78 guests
