K&B 7.5 inboard model 9181, no start
Postby k&bkiller » Sat Jul 02, 2011 7:03 pm
just got engine from dealer repair and just can not get it to start. it will start if i prime from the gloplug port. its a pressurized fuel system and lines are clear. while the engine is turning over i can see that fuel is not syphoning to the carb from the tank. lines are tight and not leaking. tank is higher than carb, fuel line is approx. 8 inches long (spec calls for 5 inches), the remote needle is approx. 3/4 inch higher than carb/tank level line and centered between carb and tank. why is the carb not receiving the fuel to start?
k&bkiller
Postby MECOA » Sun Jul 17, 2011 8:43 pm
which induction version is it?
See these FAQ's
http://www.mecoa.com/faq/crankshafts/cr ... rrotor.htm
Make sure the crank pin is in the right place if this is waht you have.
or does it have the correct crank?
http://www.mecoa.com/faq/crankshafts/cr ... /crank.htm
Postby k&bkiller » Wed Jul 27, 2011 4:16 pm
I am sure it has all the correct anatomy since MECOA did the repair, and I am pretty sure that they ran it to make sure it works also. what I am not sure about is the orientation of the remote needle valve location. I did some changes with location of the remote needle valve and have to go try it out now. I also changed the style fuel tank, so I am thinking its going to be a trial and error basis.
k&bkiller
Users browsing this forum: No registered users and 134 guests
