by JohnC » Sat Jul 02, 2011 2:00 pm
Recently was giving a K&B 3.5 OB on a Tunnel hull boat. With very little work it was running great. Recently had a flex shaft failure. Replaced the shaft and after the engine ran for a few seconds it stopped and my starter could not turn over the engine. I notice something in the drive system was causing the engine to not turn over. I took apart and noticed that the prop shaft assembly was cracked. The prop shock was missing. There is not a listing for that part. 56-8731. Is that part no longer needed? Any help would be great.
JohnC
by MECOA » Sun Jul 17, 2011 8:33 pm
Yes it is listed here
if you search by the number.
I fixed the cart so it does show in the 3.5 list.
Users browsing this forum: No registered users and 204 guests
