Hi,
Can the Venturi & NVA from the K&B .40 CL Engine #99-4051 be used on an 8011 Engine to convert it to C/L? If so are they available from MECOA & at what prices? I'd like to convert my 8011 to Control Line.
Thanks.
au88da wrote:Hi,
Thanks.
au88da wrote:I've now sourced these direct fit options:
Enya Delrin Venturi # 45B21P
This has a 7mm Venturi / 11mm Shank & is from the Enya 45BB 6001 Engine.
Enya Standard NVA # 60220
This is from the Enya 40-60,SS40/SS50,50CX,60 CL Engines.
Both are now fitted & I'll be bench testing the engine soon.
Hope this helps someone else looking for a simple C/L conversion for their K&B 8011!
Users browsing this forum: No registered users and 145 guests
